j wackerly wrote:
...... This car was a lemon from day one Ford had it in the shop 4 times for transmission and module problem
transmission and module problems? Any chance one of those times when Ford was doing transmission work on it, they did something wrong that put some stress on those frame pieces that led to this happening? Just a guess.
Or if it was a lemon with lots of issues from day one, that would suggest maybe this was a manufacturing defect of some kind from the beginning on this one particular vehicle, and you were just the unlucky one that got the one that had this defect, among others.
Seems hard to believe this is a design defect with the frame on *all* Ford Focuses, or we'd be seeing about a lot more of these failures.
I've flat towed Ford sedans similar to this for 8 years (a Ford Fusion Hybrid for 5 years, and a Ford Taurus for last 3 years) for many, many miles. Have not had any issues with either of them.
...Bottom line if you are going to flat tow make sure it is a full frame or Unibody that is all one piece with no stops and stay away from Ford.
Totally understand your concern with what you went through, and why you personally would never want to buy a Ford again (I probably wouldn't, either). And, I agree that full frame or unibody wiht all one piece around the front would be a safer bet. However, its probably painting with an awfully wide brush to suggest staying away from Ford entirely.
