cfendya wrote:
It's a 2015 Yukon minus the heavy duty trailer package. We have the 3.08's but the Service Part Description sticker shows the vehicle came equipped with the Oil and Trans cooler. Max payload sticker shows 1500lbs and the hitch show's max tongue weight of 1000lbs. I'm figuring approx 500lbs of gear in the Yukon leaving 1000lbs of payload (tongue weight). Max towing capacity is 6300lbs.
TT's we're looking at have a tongue weight of around 500lbs with empty weight of 5100/5300lbs. Assuming full of clean water we'll probably be around 5500/5800lbs.
Your available payload is much less than your estimate. Deductions, from your payload capacity, include everything and everybody, you put in or on the vehicle. In addition to that 500 lbs of gear, you need to subtract the weight of your family.
Your max tow capacity (6300 lbs) is considering a 150 lb driver who, has no cargo, and has no passengers. As you load people and gear into the vehicle, your tow capacity and payload go down, pound for pound.
Average trailer load (pots and pans, dishes, utensils, bedding, bath linens, tools, camp chairs, BBQ, groceries, water, etc) is closer to 1000 lbs. A trailer with 5300 lb empty weight will be more like 6300 when ready to camp.
Average tongue weight is 12 - 13 percent of loaded trailer weight. A 6300 lb trailer could have tongue weight over 800 lbs. A weight distribution hitch will add another 80 - 100 lbs.
