Imichaelgrossma
Mar 17, 2018Explorer
2016 Keystone Cougar RV Bike Rack Warning
About a mile south of the GW Bridge traveling north on the New Jersey turnpike, passing cars kept waving at me and pointing to the rear of my 2016 34.5' Keystone Cougar. I pulled over to discover that the bike rack was dragging on the road. The rack has a label rating it to hold 200 lbs, and I had about 100 lbs on it. But the heavy steel beams that support it had bent and lowered the unit on to the road. Needless to say this was dangerous. I was able to remove its load and finally to travel away slowly with the rack still about 8" off the ground. But before I removed it, the dragging tire could well have ripped off and hit other cars ... a dangerous situation. Searching for this issue on the internet, I see that others have had the same problem - and they also warn this is dangerous. So if you have a similar bike rack, either do not use it, or inspect it frequently for bending steel supports. It could well be life-threatening.
❚ Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?
- Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM TECHNICAL SUPPORT
