carringb
Jul 02, 2018Explorer
Step 1 is to find all your weights, including:
-Actual trailer weights how it sits now (not how it was built at the factory)
-Trailer static tongue weight
-Front and rear weights of your Sante Fe, with and without the trailer.
It's a lot of work, but only that will tell you if its a potential hitch setup issue, or if you're just simply overloaded.
Choppiness or surging in some cases is caused by a flex in the hitch system (but sometimes just under-damped suspension on either the TV or trailer), so it's important to find out for sure what's going on.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
