- IdaDExplorer
Etstorm wrote:
Andersen Ultimate is also an option
I've used the steel rail mount version for several years and it's solid, and I think it's rated for 20,000 lbs. Around that, anyway.
I don't mind having rails in my bed. They actually make for some handy and solid tie-down points for cargo. - EtstormExplorerAndersen Ultimate is also an option
- Cummins12V98Explorer III
ACZL wrote:
I also would like to know what rails OP has. On my '15 F350 SRW, used Reese rails/brackets. On my '17 F350 DRW, used B&W rails/brackets. Man oh man could not believe how much more beefier the B&W's were compared to Reese. Having also bought a B&W 18k Patriot when we had the '15, never again will I go back to Reese.
Another company cheaping out and relying on their name! - wrogersExplorerThe Demco 21k Premier double pivot.
https://www.demco-products.com/rv-towing/hijacker-5th-wheel-hitches/premier-series/21-k-double-pivot
I have this one and it is excellent. - DurbExplorerCurious. Over half the posts are recommending B&W products when they don't even manufacture a hitch that meets the OP's criteria. Let's see...your rig weighs 20 thousand pounds, use an 18 thousand pound hitch, that's pretty close. Or....I exceeded the capacity of my 18k Patriot, so you should be fine. Am I seeing bad advice here?
- ACZLExplorerI also would like to know what rails OP has. On my '15 F350 SRW, used Reese rails/brackets. On my '17 F350 DRW, used B&W rails/brackets. Man oh man could not believe how much more beefier the B&W's were compared to Reese. Having also bought a B&W 18k Patriot when we had the '15, never again will I go back to Reese.
- DurbExplorerTrailer Saver TS3, 25k. Might as well have a comfortable ride in the process.
MFL wrote:
Cummins12V98 wrote:
Why not install pucks and install a B&W. Eliminate the slop completely.
Yup, best idea, if you really need 20K minimun rating. B&W makes an 18K rail mount, that is solid, and could be trusted to the max.
Jerry
I am proof positive that a 18k B&W doesn’t blow up at 18,001#. I towed 19k several years with my old 18k Companion. - jerem0621Explorer II
- MFLNomad II
Jerry
Looking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 28, 2026
