Misterk3's avatar
Misterk3
2WD Excursion fishtails
I recently purchased a 2002 Excursion 2WD with the 6.8. I have a 26' travel trailer @ approx. 5200 lbs loaded weight. I was driving a new asphalt patch of highway in a light rain and the Ex started fishtailing at times in a crosswind.
I have been researching forums and found this to be a typical problem.
I have used two other vehicles to tow the same rig using the same brake controller and anti-sway hitch and trailer loaded the same way and never encountered this before. One was a 1999 F150 2WD and the other was a 2001 GMC 2500 pickup (not the HD).
I am wondering if anyone here has any advice on mods to fix the problem.
I am leaning toward installing F250 rear springs and Gas Magnum Monroe shocks. I have also read much about using the Hellwig 7643 sway bar kit and heavier shocks.
A WD hitch is out of play as I can't really afford it right now plus it shouldn't be required if my suspension is up to the task.
Any help is useful. Thanks.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
