Misterk3's avatar
Misterk3
2WD Excursion fishtails
I recently purchased a 2002 Excursion 2WD with the 6.8. I have a 26' travel trailer @ approx. 5200 lbs loaded weight. I was driving a new asphalt patch of highway in a light rain and the Ex started fishtailing at times in a crosswind.
I have been researching forums and found this to be a typical problem.
I have used two other vehicles to tow the same rig using the same brake controller and anti-sway hitch and trailer loaded the same way and never encountered this before. One was a 1999 F150 2WD and the other was a 2001 GMC 2500 pickup (not the HD).
I am wondering if anyone here has any advice on mods to fix the problem.
I am leaning toward installing F250 rear springs and Gas Magnum Monroe shocks. I have also read much about using the Hellwig 7643 sway bar kit and heavier shocks.
A WD hitch is out of play as I can't really afford it right now plus it shouldn't be required if my suspension is up to the task.
Any help is useful. Thanks.
  • I have never needed a WD hitch for this trailer before. I am curious why I would need one now other than the Ex has soft spring rates. I can get the parts through a local contact but he doesn't handle towing systems.
    I can look into a WD setup as well but the local guys were asking 650-800 bucks. The suspension mods would be around 300.
  • I agree with the other two, check your WD set up. I am towing a 36' TT Over 9000#. I am using a Blue OX swaypro.
  • you should be spending your money on a good WDH, not springs and shocks.
    a 4pt Equal-i-zer WDH can be purchased for $432 with free shipping from RVW.
  • So you can afford to put in new springs and shocks or a Helwig sway bar but can't afford a proper WD hitch? If you feel you need heavier springs and new shocks, then your suspension, as you say, isn't up to the task. There is no substitution for a proper hitch, and they aren't that expensive.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
