Colorado #5 wrote:
drsteve wrote:
Judging by the questions you are asking, I get the idea that you are not very familiar with electricity. Do you have experience with home wiring projects? Adding a circuit for an RV is not difficult, but it can be done wrong, resulting in damage to your RV. There is also always a chance of hurting yourself when dealing with electricity.
If you aren't familiar, you might consider getting a friend who is experienced to help out, or hiring an electrician.
Well... I wired a sub-panel off my breaker panel and then wired a 220 circuit for my 60 gallon air compressor.
I took a long time making sure I had things right and asked a lot of stupid questions to be sure I didn't burn anything up.
It passed inspection so I'm good.
Now all I gotta do is get the right breaker, run it off my sub-panel to an outdoor enclosure with the right receptacle. All this time I thought it was a simple 110 hookup not 220... So now I gotta make sure I have my "you know what" together before I plug anything in.
Thus more stupid questions.
You said the manual says it is 30 amps? The plug only has three prongs? DO NOT WIRE IT 220!!!
