While PastorCharlie is confused, you are not correct either.
By direct measurement, my 13500 btu Dometic draws as little as 1100 watts continuous and as much as 1900 watts depending on the ambient temperature and how long it has been running. Start up surge may be as much as six times the running wattage.
The reason that adapters burn is because of low voltage. That can be addressed by having an autoformer to boost the voltage.
jkwilson wrote:
PastorCharlie wrote:
A 1350 watt A/C uses less current than a 1500 watt floor heater. 1350 watts pull 11.25 AMPs. It will do just fine on either a 15 or 20 AMP circuit.
How many RVs have 1350W AC?
Most are at least 13,500 BTU/hr which translates into at least 2000W with starting current over 3000W.
And I can tell you from first hand experience you can’t run them with an adapter on a 15 or 20A circuit without burning up adapters.
