Mickeyfan0805's avatar
Apr 15, 2014
30 degrees for 3-4 hours...
It's supposed to drop to 30 degrees for 3-4 hours overnight tomorrow, then well back into the 40's during the day. It seems that getting just below 32, for only a couple of hours, should be a non-issue, and since I don't have a compressor, the concept of adding all that antifreeze for just one night seems like overkill. But, I don't want to make a mistake.
Would you be concerned?
  • No problem, it will have to get down into the low 20's for many hours (6-8) before you need to worry. Your water temp is starting out at probably 50F and it takes a long time for stuff to freeze. If you're concerned, stick an electric heater in the RV set at low temp, open the cabinet doors where there is a waterline and the bathroom door and sleep tight.
  • No had the same situation in Michigan today and wasn't concerned...
Looking for advice before your next adventure? Look no further.25,131 PostsLatest Activity: May 12, 2025
