thirtydaZe's avatar
Jul 29, 2015
30a cord extension, how much is to much?
I bought a 50' extension to get power down my driveway to the street. Wanting to be able to run my air.
Anyhow i got to thinking, leaving it on the driveway will create a situation where it will potentially have to be run over by my wifes car.
Another cord i could go around the driveway. Will this all be to much cord?
Like i said id like to be able to run the ac when im prepping for a trip.
  • If it won't fit in the driveway, the cheapest solution is to put the cord, where she'll drive over it, between two 2X4s x 8'. You should have a couple in the garage someplace.
    Bill
  • If you're basically running just the air conditioner, I don't think you'd run into any significant problems. You can have a pretty long run of 10 gauge wire for a 15A or so load without undue voltage drop. The ideal answer would be to measure the voltage and see what sort of a drop you get in practice.
    If you're running the air conditioner and the fridge and the water heater and a vacuum cleaner...well, that could be more troublesome.
    I take it that it's not possible to put the RV in the driveway while prepping it and parking the cars on the street? That would seem to me to be the best and easiest solution all around if it's doable.
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
