Hopes_Haven's avatar
Hopes_Haven
3500 lb weight restriction...
Hey guys...
We have had a 35' pusher for some time now and am looking to flat tow our 14 Equinox. The weight rating on the MH is 3500 with the toad closer to 4000. I know I'm not the only one looking to "push the envelope" but wondering if anyone has any comments/opinions here.
Roy
  • Thanks for the help! 94 Vectra with a beefy looking Class III. I plan on having the hitch checked and surveyed. It's towed a single axle pace (toys, you know how that goes) all over the country without problems but......
    Thanks again for the input!
  • Hopes Haven wrote:
    The specs on the MH indicate that the hitch is rated for 3500 lbs.
    ok, good. in general, the maximum amount of weight you can safely tow will be the lesser of the following:
    • the GCWR (gross combination weight rating) of the MH minus the actual weight of the MH as it is loaded for travel (includes fuel, fresh water, food, clothing, people, pets, supplies, eyc)
    • the weight rating of your tow bar
    • the weight rating of your hitch
    this is why it's vital to know what your MH weighs as it is loaded and configure for travel before choosing a toad. Your MH will not collapse if it is overloaded but you will experience handling issues as well as longer braking distances and accelerated wear on suspension, brakes, steering, etc.
    in your case the weight rating of the hitch is very likely the lesser of the three. IMO there's no way around that. yes, some folks have changed out the hitch but a friend who should know tells me that there is more to be done than that in order to tow additional weight. changes to the frame, brakes, suspension, cooling system, etc. that's way beyond my expertise so if you decide to replace your current hitch with a 5K hitch I would consult with the mfg. of your MH to see what if anything can be/should be done to increase the towing weight. assuming you can swap to a 5000-lb hitch be sure to check the other conditions I listed above before spending dollar 1.
    good luck.
  • Tell us about your rig. 3500lbs seems low for a Diesel, how old is it?
  • Unfortunately EVERYONE has an opinion. Mine is DO NOT exceed the lowest rating when towing. You may never have a problem, but if something broke or came loose all kinds of people would be examining your set up. Just my $.02
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
