Lynnmor wrote:
Here is a photo of an actual bearing, it measures 1.651" where it contacts the shoulder.
OK, so the shoulder (1.72) minus your measurement (1.651) = 0.069 difference in diameter, so the overlap is half that, 0.0345. From the drawings, I came up with 0.032 as a minimum.
So, what's your point, and explain why no one else is having this problem.
Oh, and what did you base your claim about the contact being "about .020" and can be as little as zero using the print tolerances." What has a tolerance of .020, or even .010?
