I found this, this tells us having a resultant clearance of 0.0019" between the bearing bore and the spindle OD is out of tolerance by 0.0007" too big.
Your bearing would fall in the 0" to 3" bore bearing chart on page 2
https://www.timken.com/pdf/10829_MDV5-Correct-Fits-For-Your-Wheel-Bearing.pdfAs I thought, the ideal middle of the clearance resultant fit spec is 0.0007" clear between spindle and bearing.  They declare a min of 0.0002" clear to 0.0012" max between the shaft and the bearing.  See page 2, under bearing cone bore diameter.
It looks like you to much running clearance between the shaft and the bearing bore.
Hope this helps.
John
