Lynnmor's avatar
Lynnmor
Explorer II
Feb 20, 2018
3500lb axles bad design
Probably most medium size trailers have the 3500lb axles and 10" brakes. The design of the spindles has little to no shoulder to locate the inner bearing. When I looked up the blueprints, I found that the spindle shoulder has a contact area against the ground surface of the bearing of about .020" and can be as little as zero using the print tolerances. That extremely small contact area can cause burrs, seal damage, loss of bearing adjustment and bearing alignment.
Today, I pulled and serviced all four hubs and found contaminated grease in two of them. The metal wearing away from the spindle contact area was the issue. The ground surface of a bearing is where it is to take the load, not the roughed in clearance radius.
To show you what I am talking about, in this photo is the blackened grease and a narrow band of metal which is the contact area that takes the lateral load of the trailer.
Here is a photo showing the result of the bearing radius carving its way into the spindle shoulder.
This photo shows the bearing with bluing so that the contact area can be found. Of course the bearing is on the spindle backwards for its photo op. The narrow dark blue band is the only support designed into this spindle. The lighter blue areas are where the roughed in radius is now locating the bearing.
I do not have an easy fix for this design fault. Short of replacing the axles with 5200lb units, all we can do is frequent bearing cleaning and repacking. For those that choose to use the grease fittings, just remember that the metal shards will be pushed to the outer bearing and the bearing adjustment still needs to be done frequently.
Here is a view of the metal shards I am talking about:
  • The seal surface is not a sleeve, it simply is too small in diameter giving virtually no support to the bearing. Even if the shoulder could be trued, you would be back to basically a sharp corner as the only lateral contact between the bearing and the spindle.
    When a bearing is manufactured, the steel blank has the radius cut in so that area will not be touched by the finish grinding operation. That surface is not expected to be used and may not run true, it is just clearance for the spindle radius.
    There is nothing to stop a bearing from turning on a spindle, as you know, the bearings are a slip fit on this type of axle. With the extremely small shoulder contact, bearing adjustment is lost in short order. The seal inside diameter should be 1/4” larger giving full support to the bearing.
    This is a #84 spindle and is used by all the axle brands, it is poor design and has nothing to do with the quality of my work. I posted about this several years ago, only to have the thread locked in a matter of hours.
  • The seal surface seems to be a pressed-on sleeve. Could a person not pull the spindle and face back the shoulder slightly to allow the inner race to seat on the seal sleeve? GD
  • Were the bearings tightened properly? Looks like the inner race was turning, and it is not supposed to do!
  • Thanks for sharing. I have 3500 lb axles. Good to know where to look. Might also explain why I have had issues with 2 axles. When I repack in the spring I will have to take a close look. I don't remember mine having this issue when I clean off the grease. I would think the cloth would stick to the metal burrs when wiping off. Guess I just need to make extra sure.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
