My new travel trailer has 50 amp service and two air conditioners. When running both air conditioners the draw is 43 Amps does that mean I’m almost maxed out??
50 amps units actually have two 50 amp circuits so in reality you have 100 amps of current split across two separate circuits in you RV. I would guess each AC unit is on a separate circuit in your RV. If you truly have a 50 amp hookup to your camper then you will not have a problem.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
