My new travel trailer has 50 amp service and two air conditioners. When running both air conditioners the draw is 43 Amps does that mean I’m almost maxed out??
If both ac’s are on one leg and everything else is on the other you should be ok as long as you’re plugged into a 50 amp post. The question I have is what happens when you’re limited to 30.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
