My new travel trailer has 50 amp service and two air conditioners. When running both air conditioners the draw is 43 Amps does that mean I’m almost maxed out??
Startup on each is probably 13-15 amps and running at 8-10 amps each. If you are seeing 43 amps, could you be counting the electric element in the water heater and the charger in the inverter?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
