Skipg's avatar
Skipg
50 Amp service question
My new travel trailer has 50 amp service and two air conditioners. When running both air conditioners the draw is 43 Amps does that mean I’m almost maxed out??
  • Skipg wrote:
    The The two air conditioners are on one leg does that mean the other appliances are on the other leg?
    It means that the manufacturer just didn’t care. You will have to do the checking to see what each breaker is connected to.
  • Are you certain they are on one leg? That would be silly to say the least.
  • The The two air conditioners are on one leg does that mean the other appliances are on the other leg?
    What is telling you 43 amps?
  • 50 amps units actually have two 50 amp circuits so in reality you have 100 amps of current split across two separate circuits in you RV. I would guess each AC unit is on a separate circuit in your RV. If you truly have a 50 amp hookup to your camper then you will not have a problem.
  • It depends. If they are both on the same leg, yes, but they should be on opposite legs of the 50 amp 120V/240V connection. A 50 amp RV service has 2 50 amp legs, for a total of 100 amps. If the loads are equally divided between the legs, you can actually draw 100 amps from a 50 amp service. Somewhat confusing, but that is the way it is...
Looking for advice before your next adventure? Look no further.25,126 PostsLatest Activity: Apr 19, 2025
