dodge guy wrote:
ScottG wrote:
dodge guy wrote:
Well first off you can’t use a 220V circuit on a 50A RV!
Second higher amps is always the better way to go.
But since you’re wiring everything, why not just run a couple 50A RV services with a 30A RV outlet.
Every 50A RV has 240VAC coming into it but it's then separated into two 120VAC circuits.
Look at the wiring of a 50A RV outlet. It is not 240V! Now you can wire in 240 after the panel in the RV. But coming in, no it’s 2 120V 50A circuits. Just adding up the voltage does not make it 240!
I'm sorry but you just don't understand what this circuit is. It's simply a 240VAC range outlet. It does measure 240 across in your RV's panel and yes, adding up two 120VAC circuits that are on opposite sides of a split phase does give you 240V.
Maybe we're just getting stuck in semantics here..
