RCMAN46
Mar 10, 2015Explorer
Level the trailer while on the landing gear.
Measure from the overhang to the ground.
Now measure the height of your truck rails to the ground.
If the trailer distance is not more than 4 inches than the truck you will not be able to tow the trailer level regardless of the hitch system used.
If you have one of those trucks that have no squat when 2000 lbs is put on the hitch than the difference has to be 6 or more inches.
If you have a truck that squats more than 2 inches then the difference can be less by 1 inch for each inch over 2 inches.
The average for many trucks is a 2 inch squat.
A level trailer will handle better and the tire wear will be more even on the trailer.
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
