- C_B_Explorer IINo matter what kind of bike carrier you use make sure it is mounted tight (no wiggle or slop) in the receiver tube.
Top bolt holds Thule 2 bike carrier solid in reciever.
C.B. - Grit_dogNavigator III
JRscooby wrote:
:E
Not sure what kind of carrier but to avoid the bouncing it would be subject to on the back of trailer I would look at making a mount for the pin box, haul on the front of trailer.
Mmmkay…. - way2rollTrailblazerX2 on the swagman. Easy to use, solid and doesn't scratch the bikes. I will say though I've had good luck with a fork mount in the bins where they are totally enclosed.
- JRscoobyExplorer IINot sure what kind of carrier but to avoid the bouncing it would be subject to on the back of trailer I would look at making a mount for the pin box, haul on the front of trailer.
- ScottGNomadSwagman. I've been using the same one for 16 years and 2 trailers.
I destroyed two other name-brand units before that (and ripped one bumper nearly off). They just couldn't hold up to the movement back there.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
