Picinisco's avatar
Picinisco
5th wheel hitch maintenance
I aquired a Draw Tite 5th wheel hitch that has scratches on the skid plate that has resulted in flaking paint. I have wire wheeled the loose paint and would like to repaint it. What kind of paint should i use or should i just grease the entire surface.
  • I keep my hitch sprayed with something like WD40 or an equivalent, to reduce corrosion. I don't like smearing grease all over the plate as it collects dirt & dust and must be cleaned prior to hitching up; a real mess. I also have a nylon disc on my hitch pin which helps.
  • Once a year I wire brush the hitch plate down then repaint it using Rust-Oleum Black
    (touch up hitch and pin box as needed)
    I also use a 'teflon' plate
    NO GREASE on head (which just ends up messy/attracts--holds dirt & grit/gets on you, pin box and clothes)
    NO GREASE.....that's what the 'teflon' lube plate os for
  • They were probably powder coated when new. Personally I would wire brush it allmoff the swivel plate and grease it liberally. Less friction that way.
