opschief
Oct 22, 2019Explorer
5th wheel hitches
OKay... I/m looking for anyone who had or is currently using an Andersen Ultimate hitch. The Good and Bad. I just purchased a 2020 GMC 2500 ATC need to get a hitch to fit my vehicle. the only two options currently available are the Andersen Ultimate or B&W companion slider due the change in the bed size from the 2019 models my truck has the 5th wheel prep package withe OEM puck and goose neck system so i can use either configuration. Undecided.... which discretion to go. Ultimate much lighter but is it strong enough? or B&W 20K hitch but much heavier. I plan to remove the hitch when not towing to have a clean bed no rails.... that's why i have the puck system. The 5th wheel a Montana weight 13-14K... probably 16K loaded.... Thanks.
For all of you weight police out there...... I would like to make a correction.... my 5th wheel weight unload is 13,100k so i'm looking at 14-14,500 k loaded pin weight 2,400..... again i'm looking for input on which hitch to purchase.... The truck and 5th wheel not an issue . The new 5th wheel is the same weight as my bolder one and towed it with a 2007 chevy diesel over 10,000 miles... and not the first issue towing.The new truck actually capable of towing 2 k more than the old truck. But thanks for your concerns.
