arcticfoxpuller's avatar
Dec 07, 2016
5th wheel nose high
After putting the camper in the shop for the winter I went and raised the front landing gear as high as I could. With my short legs I can now walk under the front. Will this hurt the suspension or tires. It's really nose high.
THANKS
  • It will throw more weight on the rear axle. I'd just leave it level.
    Ken
  • I also wouldn't worry too much about it. Make sure the tires are chocked good. You could also build some 2x12 or similar runners to drive up on and raise the whole trailer to eliminate some of the angle. stack a few boards and you can easily gain 6 - 8 inches in height.
  • It's just kinda handy for me as I can walk under the front to get access to another door in the shop.
    :h
    Old-Bisquit has the answer. I can still manage that at over 7 decades but it does put a strain on my bodily overhang. :W
  • MFL wrote:
    First off, is there a good reason for doing this?
    IMO, it is not the best idea to extend landing gear to the limit. I think you are putting unnecessary stress on your suspension/springs, as well as making the rear tires support most of the weight.
    I would not do this, especially long term!
    Jerry
    C'mon. Really??
  • It's inside the shop. No fridge running. Not up against the landing gear stops. It's just kinda handy for me as I can walk under the front to get access to another door in the shop.
  • Hang a ribbon from king pin so you quit running into it and lower the front back down to level
  • First off, is there a good reason for doing this?
    Jerry
  • Is it nose-high as compared to actual level or ground level?
  • As long as you haven't over-extended the landing gear and the trailer is protected from gusty side winds, you should be OK. If the frig is turned on, you may damage it - they need to be level. My question would be: why would you want to do this?
    Rob
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
