MLWalton's avatar
MLWalton
5th wheel or bumper pull
Hey, new guy here. I have a 2019 F-250 6.2L 3:73 and debating on getting a 5th wheel or bumper pull TT. The 5th wheel I'm looking at has a dry weight of 10k and is 35 feet in length where as the bumper pull is 39 feet in length and it's dry weight is 8300#. Please give me some opinions on why you would chose one over the other. Thank you all in advance for helping the new guy.
  • For starters forget the dry weight figures. The gross weight (GVWR) is the the number that matters. Will your truck with the 6.2L handle fully loaded trailers? I like the 5th wheel for it's stability in crosswinds but I don't like the steps to the bedroom but I do like that 5th wheels are easier to maneuver and backup.
  • General opinion is that a 5er tows more stable than an equal length TT. But you know what opinions are worth. Many say a TT set up properly tows just as well.
    The truck and 5er total length will be a LOT shorter than the truck and 39’ TT.
    The 5er will be easier to get into tight sites since you can back in a tighter turn.
    TT doesn’t have inside steps you have to go up and down. A plus.
    Most 5ers have a lot of storage space under the front elevated area.
    Pros and cons for each.
    But you do need to check your truck payload rating compared to hitch weight.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Feb 24, 2026
