cruiser51
Feb 14, 2016Explorer
5th wheel towing help
I have a Ford f250 crew with a 6.7 diesel. It has tow capacity f 14k. I am looking a 5th wheel of approx 10 with a 100 lb pin. Can I tow this ok, any help would b appreciated Thanks
MFL wrote:cruiser51 wrote:
OK more info, 2013 Sabre 35' 9800# dry weight and 1774 on the pin.
Your 250 should handle that trailer quite easily. With the 6.7 diesel, your door payload sticker will be low (about 2,100-2300). This is due to your class rated 10,000 lb GVWR.
Your diesel will pull it easily, and your rear axle and tires will have enough capacity to carry that trailer, even when loaded for camping.
Jerry
