- wa8yxmExplorer IIIDrop into your local Auto Parts store or department,
A standard Wedge Base dash indicator lamp will fit nicely in the 921's socket, let me see if I have a number handy.
Number 168. You do need to be careful to center the lamp in the socket when you install it though, Bit narrower. - YamaDooedExplorerI replaced the 921 lamps in two fixtures with a 921 NA which is just the amber version and much easier on the eyes.
- Fastfwd75Explorer
tenbear wrote:
How dim do you want to go? Do a search on eBay for "T10 led warm white". Something equivalent to the 921 bulb would have about 24 5050 leds, so 6 5050s would be about 1/4 as bright, and so on. Some use 1210 (3528) leds which are about half as bright as the 5050 led. Take your pick.
I'd like the one over the bed to be as dim as possible. Possibly keeping only one of the two bulbs. I read on my ipad so no bright light needed at all there.
I'd keep the one on top of the kitchen table and cooking area as bright as possible.
Also will probably pick up a nightlight for the toilet and use frontal led when I am without electricity. - tenbearExplorerHow dim do you want to go? Do a search on eBay for "T10 led warm white". Something equivalent to the 921 bulb would have about 24 5050 leds, so 6 5050s would be about 1/4 as bright, and so on. Some use 1210 (3528) leds which are about half as bright as the 5050 led. Take your pick.
- Gene_GinnyExplorerI use a 906 bulb in places only want a litle light.
#906 MINIATURE BULB GLASS WEDGE BASE - 13 Volt .69 Amp 9.315 Watt T5 Glass Wedge Base
Lumens: 75
Candle Power 6 - DiskDoctrExplorerFor electric camping, we added a couple of blue LED plugin nightlights with plastic nautical shapes- lighthouse, sailboat, seashell.
They seem to be just right for night movements, including in the bathroom, so no instant sunlight when nature calls unexpectedly during the wee hours.
Won't help for boondocking, but they are only a buck at dollar store and we're on season 3 for a couple of them ;) - mikeh449ExplorerI have found that the bulbs at home depot or lowes for 12 volt lawn lights work just fine in place of 921 but 7 watts
- Dog_FolksExplorer II
mbopp wrote:
The 921 bulb is rated at 21 candlepower.
A 922 is 15 C.P.
A 920 is 10 C.P.
The smaller 194 (same base) is 3 C.P.
I replaced my incandescent bulbs with 1210-36 LED panels.
There you go,saved a trip to NAPA. - mboppExplorerThe 921 bulb is rated at 21 candlepower.
A 922 is 15 C.P.
A 920 is 10 C.P.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
