95jersey's avatar
95jersey
A little uncomfortable with my set up...
Let me explain...
I went from a Wildwood travel trailer (22ft, 3600lbs) to a Jayco 273 Toy Hauler (31ft 6500lb, 12ft high). My tonque weight went up significantly from probably a few hundred lbs to 1000lbs. Not to mention, putting in 250-750lbs of dirt bikes behind the rear axle.
My truck is a new 2018 F150 with the 3.5TT, 10 speed, and best towing package you can get on an F150 (extra payload, rear axle upgrade, etc). It is a beast and I could not even feel my Wildwood behind me. My truck specs fully support the load of the trailer with room for safety, but I am not here to discuss specs, but more or less tow feel on highway. Please don't recommend a 250/2500, not going to buy another truck at this point.
Towing the 22ft Wildwood was a walk in the park, I didn't even need a WD hitch. I could do 75mph without blinking. The experience with the Jayco is not so nice. It gently sways and pushes me around just a little, at highway speeds (65+). Not anything significant or dangerous, just unpleasant and requiring your attention. The 18 wheelers passing by are a real joy. I have a HD-WD hitch, airbags on the truck, and 2 anti-sway bars as well. It is set up as good as it is going to get. It is 100% level and the truck has the HP to pull it without question.
I am thinking 2 factors are causing the uncomfort at highway speed (the sheer height 12ft+, and the 31ft length). I am sure the higher tonque weight and 750lbs of dirt bikes loaded past the rear axle isn't helping.
I am thinking of selling it and downgrading to a smaller unit (maybe 20-26ft toy hauler, and in the 5000lbs or less range). Before I go down this road, is there anything I am missing to make my current set up handle better? Also, if I just go down 3-4 feet in length and 1500lbs in weight, will that even improve my situation? Or am I going to have the same problem with the increased height? Would hate to downgrade and have the same **** problem.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
