- coolmom42Explorer II
Okie1 wrote:
Any water including City Water will only hold a Chlorine Residual for a few days, then you have no protection. It is always a good idea to sanitize at the beginning of each season.
This.
Don't forget the hoses and water heater.
Flush with plenty of fresh water.
You won't have a lingering chlorine taste if you don't use way too much chlorine. Calculate correctly and measure it. - nremtp143Explorer
toedtoes wrote:
I use a teaspoon of pool & spa chlorinating granules in the fresh water tank. Fill it, let it sit overnight, run it through all the faucets until drained.
Then I fill the tank again with just water. If I smell the chlorine, I may drain a second time and then refill.
My old TT had a horribly musty icky smell to the fresh water tank. Like a stagnant pool. I did the above twice and the water tasted just as good as from my home tap (which is the best tap water I've had). I did my RV when I first got it. I'll repeat if water sits for a long time and/or the taste changes.
X2! - 2oldmanExplorer II
Lspangler wrote:
Take a dump and don't flush it. After about 3 days it will be pretty much 'broken down.'
It's amazing how many people believe waste will break down in a blank tank!You would have to fill the tank and let it sit for many weeks or months for any real break down of waste to happen. - toedtoesExplorer IIII use a teaspoon of pool & spa chlorinating granules in the fresh water tank. Fill it, let it sit overnight, run it through all the faucets until drained.
My old TT had a horribly musty icky smell to the fresh water tank. Like a stagnant pool. I did the above twice and the water tasted just as good as from my home tap (which is the best tap water I've had). I did my RV when I first got it. I'll repeat if water sits for a long time and/or the taste changes. - mlts22Explorer IIA black tank is a large chamber pot. It isn't a septic tank where the waste is turned into compost. Instead, what happens is that TP and poop should be turned into liquid. With this in mind, it doesn't matter what bugs are in the tank. Because of this, it doesn't hurt to bleach it out to get rid of odors.
As for turning waste into liquid, the magical chemical I use is Dawn hand dish soap. It dissolves grease off of dishes, and when dumped in the black tank, it does quite well in doing the same exact thing to stuff in the black tank. I've been doing this for a few years now, and so far, no clogs or plumbing issues, so I'm either lucky or doing something right.
Plus, there isn't anywhere else to put the water from sanitizing the tanks. If I dumped the bleach water onto the ground, I'd leave a soggy mess of dead grass for the next person. So, I might as well have it kill odors (especially in the grey tank that can get quite stinky) and call it done. - wilcampExplorer
RAS43 wrote:
Johno02 wrote:
but its harder to get the bleach odor out.
Refill the tank and add a half cup of baking soda and pump through the system. Let it sit a couple of hours and then drain and fill. The bleach odor is gone!
Yupp, baking soda works for us, too. . . been doing this for 14 years and 3 TTs. - rockhillmanorExplorer II
You would have to fill the tank and let it sit for many weeks or months for any real break down of waste to happen. Anything you add to the tank would be for odor control only.
We have never used city water hook ups so we sanitize each spring with bleachLinc
that's not true. I use a black tank chemical that DOES break down waste. You have to read the label very carefully to find one that states it does. Most of the new ones on the market now are targeted to the greenies and all they do is add perfume.
Which the one and only time I used one of those perfume ones because I had run out of the one I use......the whole RV stunk like a french whore and set my asthma off the charts. Had to find a dump station and get rid of it asap.
I have dumped with this chemical in my tank and without and with the clear sewer connection there is definitely a difference. Our RV's are not your home sewage system. We have a small diameter exit and a blade valve just begging to get clogged up.
I don't have time while on the road to deal with clogs of any kind. And have not. The original chems that break down the waste have been on the market for years and years for RV and marine.
This is the only one I use. No sewer odor ever, no clogs. And that goes for long periods between dumping in hot, hot, Florida in the summer. :B
Packaging is very similar for this one and their natural one. Read the label and look for breaks down waste. - LspanglerExplorerIt's amazing how many people believe waste will break down in a blank tank!
Linc - BobboExplorer III
WoodGlue wrote:
Bobbo wrote:
If you double the amount of bleach, you can cut the sit time down to 1 hour
This is an old wives tale! In other words, not true.
WoodGlue
It may be an old wives tale, but it is in black and white in my Winnebago manual. That is where I got it. - WoodGlueExplorer
WoodGlue
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
