CabinetmakerII's avatar
Feb 18, 2021
How to sanitize new RV water system
While dumping tanks the other day I was looking at the "Water Control Panel" and got to wondering how to sanitize the fresh water holding tank. All of our previous RV's had a gravity feed fill port for putting water into the fresh water tank. When sanitizing the system I would simply pour a measured amount of bleach into said port and fill the tank. Run the water pump to get the bleached water into the system and let it sit overnight. Then drain and flush the system the next day. Now to the issue at hand. On this new coach, the "Tank Fill" is controlled by a valve. Simply turn the the City water valve to the Tank Fill position and the tank fills... How then do I introduce bleach into the system? Is there a siphon type connection available to put onto the bleach and the water flow takes it to the tank? Any advice would be appreciated!
Allan
