We have a 33'-0 5th wheel with single AC. When plugged in at home will the AC function properly if plugged into a 15 Amp outlet ? If so, I usually have a normal extension cord running from the 5er's p...
15 amp is no good in my opinion...you need minimum 20 amp with no other loads on the house circuit and no other loads on in the RV expect the converter with fully charged batteries. Maybe a low wattage TV on would be OK.
And yes I have done this many times on a 20 amp circuit.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
