We have a 33'-0 5th wheel with single AC. When plugged in at home will the AC function properly if plugged into a 15 Amp outlet ? If so, I usually have a normal extension cord running from the 5er's p...
Answers will vary. I am guessing you have a 30 amp rig! Extension cord needs to be a healthy size. a standard 16 or even 14 gauge cord would not be adequate. 12 gauge or a standard 30 amp RV extension cord would do better. The 30 amp extension cord could come in handy on the road. Charge up the batteries good before running AC should reduce the load and keep voltage levels up a little. How far are you talking?
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
