We have a 33'-0 5th wheel with single AC. When plugged in at home will the AC function properly if plugged into a 15 Amp outlet ? If so, I usually have a normal extension cord running from the 5er's p...
Most standard extension cords have 5-15 cord bodies. This is the NEMA standard for 15 amp. A true 20 amp is a 5-20 Nema configuration where the male end has the neutral perpendicular to the phase blade. Big thing is the gauge of the wire. Larger gauge is better. Minimum 12 gauge is best. Cord bodies are the weak point.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
