wa8yxm
Apr 01, 2019Explorer III
colliehauler wrote:
I bought a used 2009 trailer I'm rebuilding an found the A/C doesn't use a wall mounted thermostat. Controls on the unit and has ductwork. Never seen this before, commom?
I would not say "Common" but. not unusual either. In fact there is one less than six feet from where I'm typing (It is a repalcement).
Before you "Upgrade" check to make sure wiring for the wall T_Stat is already in place because swapping a Wall mount type A/C for a "Local Control" is easy.. Just tape off the wires. but the reverse is a major job if the wires are not already there.
Oh works well. and since I'm 6'2" not a problem would be if I was 4'11".
IN fact. it works better for there is NO chance I can "Brush up against it".
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
