aftermath
Aug 12, 2015Explorer III
mfifield01 wrote:
Basically I need a dry hitch weight of 400 lbs or less. Not much in that category.
Take a deep breath, it is not that bad. There are those out here that think that you can't tow anything more than a tent trailer with a half ton. If you look around at any campground you will see many trucks like yours hooked up to all sorts of trailers.
Here is my situation. I am towing a 25 ft Airstream with a GVW of 7200 and I am usually going down the road just a tad over 6100. I have weighed my setup and found that the estimated tongue weight as posted in the sales brochure is not all that close to the actual. They state 720 which is 10% of the gross, but when loaded with full propane, a spare tire and two batteries it is just over 1100. The WD hitch transfers enough back to the trailer that my actual tongue weight is 840 lbs. We do travel light since it is just the wife and I. We typically bring along a generator, some camp chairs and occasionally some firewood. We carry most of our stuff in the trailer so we are right at our payload limit.
If your truck is designed to "pull" over 10K then all you need to do is to concentrate on your payload numbers. Keep the trailer to around 6000 lbs, get a good WD hitch and look at what the tongue looks like. Are the batteries stored there, is there a spare on the tongue and how many and how big are the propane tanks? If you are planning on bringing tons of stuff from home when you camp you will likely need a bigger truck. I have been doing this with my current combo since '09 and have gone over 30K miles without any issues.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
