uintafly's avatar
uintafly
Adding a washer to my Equalizer
Hey folks,
I am not fond of the setup of my Equalizer brandh WDH from the dealer. The bars are nowhere near parallel, in fact they are probably 3" or moer out. According to my recent trip to the CAT Scales they are doing their job, but I want to get the same outcome with a better setup. I know I need to at least add 1 washer for the adjustment possibly more. From what I understand, a good starting point for a truck is 5 washers, and I currently have 4 (the same as my 4Runner and 19' TT). I have a feeling they left the ball the same and only switched the brackets to make adjustments. Can I just use any stainless steel washer that is similar size to the others, or does it take a special type? Also, is the placement of the angle set bolt completely set by the amount washers? Thanks for any advice.
Chris
  • The manual is online. It explains everything you need to know to add a washer.
  • I used a grade 8 washer from the local hardware store for a few pennies to do the same as what you're doing. Easy fix. There's lots of physics that go into the WDH, but changing the angle and not the torque lifting up on the bars wouldn't change anything, I'd think.
Looking for advice before your next adventure? Look no further.25,156 PostsLatest Activity: Aug 13, 2025
