  • Coupler is bolted on, and I notice the wheel studs are longer than normal, probably for the optional disk brake kit that was offered when originally purchased new. I just wish that kit had mounting hole dementions.
  • j-d's avatar
    j-d
    Explorer II
    For hydraulic surge, the Drum actuator has a check valve in the return flow. Disk does not.
    Is the current trailer hitch bolted or welded? Welded, more work to convert.
    Kodiak is a good brake kit.
  • BTP
    Thanks for that reminder. It seems disc needs more pressure than drum, probably a smaller dia master cyl. But nothing that another $15 doesn't fix. :)
    http://www.etrailer.com/Trailer-Coupler/Titan/T4745700.html
    BTPO1 wrote:
    Rich,
    In your response you stated that you would need a $119 actuator. Looking on the etrailer website there appears to be a different actuator for disc brakes. I don't know the difference, but says that it is designed for disc brakes. Just something to think about.
  • Rich,
  • BTP
    Thanks for that info. Glad you got it squared away.
    These plates are welded level/square, not that is makes any difference w/ disc brakes. And yes I'd need a $119 actuator.
    BTPO1 wrote:
    Rich,
    I installed electric brakes on my older steerable Demco dolly. The only problem that I had was that the spindle mounting plate was at a 45 degree angle. I did have problems with that since the magnet was not at the bottom. I was told by Dexter engineers that it would be OK to mount them at the 4 o'clock position. Not true in my case, constant problems until one day the brake froze up and a blowout occurred. I had the plates removed and re-welded by a trailer repair facility and since have had no problems with them.
    I thought about going with disc brakes, but decided against them due to the fact that I would have to buy an actuator for them and I was already set up to tow with electric brakes. JMO
  • Rich,
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
