dennislanier
Aug 01, 2013Explorer
dbbls wrote:
I use a wand to put into the tank to flush it out once a year. Couldn't do that with a systems shown above. I'll keep using my factory plug. It is very easy to remove and replace.
Agreed. Since I only drain the water heater when winterizing, I just unscrew the plastic plug and use the wand to flush out the debris and make sure it is good and clean before shutting down for winter. If I drained the water heater more often the valves shown above would certainly be a worthwhile project. I just don't see the need to drain it more than once a year under normal circumstances.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
