PenMan
Jul 31, 2013Explorer
Adding Drain Valve to Atwood Water Heater
I'm almost sure I read on the forum about someone replacing the plastic drain plug on a water heater with a valve. But, I did a search and found nothing. The water heater on my old HTT had a Suburban water heater with an anode rod so no drain valve possible. Out new TT has an Atwood water heater with a plastic or nylon drain plug. Has anyone replaced the drain plug with a valve to make draining the heater easier? If so, what material did you use? Any help would be appreciated.
