DrewE
Apr 23, 2017Explorer III
ppine wrote:
Normally light fixtures have a black wire (hot), white wire (neutral) and maybe a green ground wire.
That is true for 120V fixtures. 12V fixtures would not generally have a ground wire, and the wire colors may be a little more varied. If black and white, black is generally positive and white negative (which is usually chassis ground). If red and black or red and white, red is positive. If some other combination, your guess is as good as mine.
Occasionally there might be only one wire, with the mounting serving as the negative (ground) connection. That would be much more common for general vehicle lights like running lights or turn signals than for lights intended for RVs in particular.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
