tragusa3's avatar
tragusa3
Adjust hitch after switching to LT tires on truck?
As the topic states: I believe that my new LT tires stay firmer with less "squish". It seems logical that this accounts for the rear end staying a little higher under load than it did with P rated tires. Enough so that I think I can use one less link on my WDH. Or, is my thinking flawed? Any opinions?
I'd like to have less tension on the WDH, as for the last year, I have to raise the jack to the max to get to the link I want/need.
  • x3. Don't adjust spring bar tension, adjust hitch height. Trailer should be level or slightly nose down when the height is adjusted correctly.
  • 3oaks wrote:
    If you have changed nothing else but your tires, and if your trailer is sitting out of level (front end higher) because your tires don't "squish" as much", do not adjust the links on your WDH. Lower the hitch head assembly on the hitch shank.
    X-2
  • If you have changed nothing else but your tires, and if your trailer is sitting out of level (front end higher) because your tires don't "squish" as much", do not adjust the links on your WDH. Lower the hitch head assembly on the hitch shank.
  • If your hitch is staying higher then you have already reduced the tension some.
    I'd leave it alone.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Dec 14, 2014
