4aSong's avatar
4aSong
Adjusting equalizer bars
Followed all the manufacture instructions and have proper weight distribution on front and rear of tow vehicle but the equalizer bars are not parallel to the trailer frame, where the chain links attach to the frame the bars are high. Would like to drop the bars about a 1/2 “ but just changing to a different link on the chains also changes the weight distribution on the tow vehicle. Currently have 4 washers installed for hitch head tilt. What do I need to do to bring the bars closer to parallel ? :?
Thx
  • Just added additional washers and dropped one link on the chains and here is what my measurements are;
    Tow vehicle with no Trailer attached
    • front 35 1/8
    • rear 36
    Tow vehicle with Trailer attached (No equalizer bars installed)
    • front 35 5/8
    • rear 33 3/4
    Tow vehicle with Trailer and equalizer bars attached (6 washers - 6th link)
    • front 34 7/8
    • rear 35
    Trailer measurements (ground to bottom of box) when attach to tow vehicle and equalizer bars installed
    • front 19 7/8
    • rear 21 5/8
    Equalizer bars are now parallel with the trailer frame.
    Based on the installation instructions, these measurements show to be acceptable but comments would be appreciated.
    Thanks.... Mike
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    I'd try going to 5 washers which will tilt the bars down more. Try that and see how it works. I believe you can use standard washers but try to get the same thickness as the EQ supplied washers.
  • I currently have 750lb. bars and the trailer hitch weight is 335lbs. dry, Can just standard washers be used or will I need special washers ?
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
