tragusa3
Jul 26, 2017Explorer
The sub-soil you're dealing with will partly determine what sort of prep you need to do. I'm on a very hard red clay. We just dumped the gravel, spread it out and used it. That was 10 years ago with zero maintenance.
We used "crusher run" and it is closer to cement now than gravel. The larger the gravel you use, the better it will hold up to erosion from water. But that may not be of concern in your location.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
