rk911
Aug 09, 2014Explorer
EydieG wrote:
We have a 1999 Dutchstar DP. We have only owned it for about 2 years and so far we have towed our Ford Taurus on a dolly. We now plan to buy a truck and are getting so much conflicting advice on this we decided to turn to the experts :) We need a truck comparable in size to the Ford F150 because we will at times be towing a boat with it. Other times we will want to tow it behind our coach. We had one Ford dealer tell us that all new vehicles could be towed four down. After some research, we found this isn't true at all. (If buying new we will purchase a Ford, used could be other makes.) The truck will have to be automatic but other than that we are kind of confused on what we need. 2Wd or 4Wd New, used, what years.. etc? I have read several owner's manuals and looked at the towing guide for several years, but I would like to hear from folks who actually tow or have in the past towed a truck. Thank you so much for any advice!!!
trucks can be quite a bit heavier than autos but in any case it's important for you to know how much weight you can safely tow before you select a vehicle.
step 1: determine what your Dutch Star weighs as it is typically loaded for travel. that would include full fuel and LP tanks, as much water as you usually carry, food, clothing, pets, supplies, people and other stuff. load 'er up and take it to a certified scale and get actual weights on each axle. that's important...don't just get a total weight, get individual weights for each axle.
step 2: compare the actual axle weights to the GAWR for each axle. you're in good shape if the actual weight is less than or equal to the GAWR for that axle. if not then you'll need to unload weight from that axle. the sum of the actual weights should be less than or equal to the GVWR.
step 3: in general, the maximum amount of weight you can safely tow will be the lesser of the following:
* the GCWR of the MH minus the actual weight of the MH as determined in the above steps.
* the weight rating of your tow bar
* the weight rating of your hitch
if you're planning to tow the pickup on the dolly then the weight of the dolly has to be added to the weight of the truck. once you know how much weight you can tow you can start shopping for a truck.
good luck.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
