FIRE_UP
Aug 10, 2014Explorer
EydieG wrote:
We have a 1999 Dutchstar DP. We have only owned it for about 2 years and so far we have towed our Ford Taurus on a dolly. We now plan to buy a truck and are getting so much conflicting advice on this we decided to turn to the experts :) We need a truck comparable in size to the Ford F150 because we will at times be towing a boat with it. Other times we will want to tow it behind our coach. We had one Ford dealer tell us that all new vehicles could be towed four down. After some research, we found this isn't true at all. (If buying new we will purchase a Ford, used could be other makes.) The truck will have to be automatic but other than that we are kind of confused on what we need. 2Wd or 4Wd New, used, what years.. etc? I have read several owner's manuals and looked at the towing guide for several years, but I would like to hear from folks who actually tow or have in the past towed a truck. Thank you so much for any advice!!!
EydieG,
Well, You're getting lots of advice. It still amazes me that even many dealerships are "clueless" on towing some or, most of their vehicles. Ford, in its infinite wisdom, lost out on years and years worth of sales of it's popular F-150 4x4 to the "dinghy" towing folks out in RV land due to the fact that they didn't allow for the electronically shifted, transfer case, to have a "NEUTRAL" position. It was done like that, all the way to 2011.
Then, one day, someone at Ford, came up with a great idea, "LET'S MAKE OUR F-150 4X4, FLAT TOWABLE". And, in 2012, they made the tiny change to it's transfer case and, vuuualllllllllllla, the F-150 4x4 is now flat towable. Now, can any F-150 4x4 manufactured prior to 2012 be changed over so that it, can be flat towed, not to my knowledge.
So, in the used market, the GMC, the Chevy and, the Dodge, all in the 1500 series 4x4 automatics, can all be flat towed. It's useless to print out all the procedures for actually putting them into towing status here because, there are minute changes in those procedures, from year to year and model to model. So, if and when you pickup a pickup for towing and, you know for sure, BY READING THE OWNERS MANUAL of the intended truck, that IT IS FLAT TOWABLE, then and only then, do you need to know all about what that particular truck's detailed procedure is for readying it for flat towing.
Now, with all that being said, we've towed our 2011 GMC Sierra 1500 4x4 Extended Cab now for about, 8,000 miles and have been thoroughly satisfied with all aspects. And that means, towing it with our '04 Itasca Horizon 36GD with the C-7 330HP CAT. It does just fine in and on, all roads with the exception of grades. And just about every coach on the planet is going to slow down, on most real grades, towing a full sized truck. No biggie.
On a recent trip, ours slowed down to about 50 on some grades and, as low as about 38-40 on others. Again, no biggie, we still got to our destination. And, on many of these trips we take, we also carry a 2008 Honda Goldwing which tips the scales at just about 900 lbs. The lift, which is used to load the bike, called a "Rampage" is right at about, 275-300 lbs. So, we're tugging about 6,500 lbs. cruising on down the road and, again, it works great.
It's really nice having a truck for a toad. It allows for all kinds of options. Yep, it's not a puddle jumper small toad like many tow and, in some cases, I envy them but, it is what it is and, we're happy. You gotta do what you gotta do to accomplish your purpose. Setting up the GMC with base plates was a snap. I did it in about 3/4 of a day. I also did the wiring for the lights which, also took about 3/4 of a day. I'm one that utilizes the stock tail lights as toad lights because I want following drivers to see the exact same thing in tail light action when towing it, as they see when it's being driven. It's a preference thing.
So, anyway, good luck and hope you find what you're looking for.
Scott
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 10, 2026
