jkbrea
May 28, 2014Explorer
Advice on Honda 2000 Generator
I have a pair of 2000's with the parallel cables. They run great and I really like them. I service them by cleaning the filter, changing the oil often and replacing plugs. I can take them out after months of storage and they start right up. The only problem is when I'm camping I leave them outdoors locked with a cable. When the temperature drops overnight and I try to start them, they run for about 5 seconds then stall. The red oil light goes on for a few seconds. This goes on for about ten minutes before they run properly. I thought it may be the altitude but last time I brought one inside the RV overnight. In the morning it worked perfect. I'm no mechanic but I believe the oil may be thickening up some with the cold and not able to pump properly until it warms up some. Anyone ever have this issue and should I try a different weight oil? Using 10w30 now.
