JBarca
Nov 24, 2016Nomad II
riven1950 wrote:
choice 1 Apex 249RBS
base weight 4770
hitch weight480
length 28'3" with tongue (box about 25'3")
choice 2 Apex 279RLSS
base weight 5490
hitch weight 620
length 31' with tongue ( box about 28')
Hi again Riven,
I did not see this post when I responded to your other. The 249RBS 249RBSwill fit your truck much better and leaving you breathing room. The 279RLSS like my other reply said, it going to tax your truck beyond the limits. The 269RBSS is going to push it too you listed in the other post. The 249RBS is a much better choice.
Making the jump to the longer TT, you will need a good WD hitch with a good anti sway control. You are now beyond a single friction bar in the 28" and up range if that is what you have.
Hope this helps and good luck
John
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
