TNGW1500SE
Apr 29, 2017Explorer
DutchmenSport wrote:
The awning itself has slid and is now out of square. The cure is relatively simple, but the fix may be harder.
All you need to do is move the awning in the track, either on the trailer side, or the tube roller slide. Depending upon if the out-of-alignment is forward or backward. That's the cure.
This fix is not so easy. There is a set screw somewhere in the awning, where it slides into the track. You'll need to remove that set screw, which is holding the fabric in place, and that will let you slide the awning forward or back in the track. The hard part is actually moving the fabric in the track. They can be very stubborn. You may need 2 people. One person to pull on the tube, the other person to pull the opposite direction on the awning. If adjusting on the trailer grove, it just takes brute force sometimes to break it free so it will move. Thus the "fix" can be difficult. It just takes brute muscle, but that's all that's wrong with your awning arms. Don't do any adjustments on them. It's all the square of the awning to the trailer to the awning roller that's the problem.
Thanks! I didn't see any set screw so I pulled on the fabric and it moved! I moved it about a 1/4 inch and it seems to work fine now.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 07, 2026
