Beltzy's avatar
Beltzy
AHHH! Dropped my water tank!
So friday night i got my water filled and ready for a Dunes filled weekend... Pulled my hose and heard a loud boom! Went over to look under the trailer and the belly was bowed way down. first thing first was to dump all 90 gallons of water in the street and pace in circles thinking about the trip being over before it started the "how much is this gonna cost". I got the water drained and cut into the belly to find my water tank dropped off the angle bracked it sits in. Upon further investigation i found the bracket moved back because of two self tapping screws that held it were broken, and not freshly broken. Like maybe broken when it was assembled. Long story short i pulled the two broken screws out and replaced then with some good ole grade 8 bolts n nuts, put the bracked back and the tank back up. I filled it with water and we were off in the AM thankfully no problems. Glad it was an easy fix. I used gorilla tape to close belly the cover, anyone ever had to cut into the belly of their camper? and what did you use to reseal it?
  • I agree 2oldman: When you think of the weight in a full water tank, plus the cost of hauling H2O around, why do it? Even big trucks are specially constructed for hauling of liquids.
  • DutchmenSport wrote:
    FYI, I never travel with water in my fresh tank for the very reason you just described. There's a lot of weight in those tanks, and then you add all the bumping up and down and water movement inside the tank, and ...
    It's a wonder we don't see this more often, considering the number of people who report travelling with full water.
  • Gorilla tape will probably do. I would not attempt to change it, since it's already there, but do keep an eye on it and if it does start to come off, then go to plan "B".
    FYI, I never travel with water in my fresh tank for the very reason you just described. There's a lot of weight in those tanks, and then you add all the bumping up and down and water movement inside the tank, and ... well ... I've just never had confidence to travel with full tanks. Moving around the campground, no problem, 5, 10 mph, but at highway speeds, and highway bumps, and highway chuck holes and railroad tracks and such ... nah, not comfortable at all.
    For longer trips, we take a separate 6 gallon jug of water for on-the road usage, and keep the tanks as empty as possible.
  • bob213 wrote:
    Glad everything went well. Would another brace help it from moving again? Gorilla tape usually holds. I heard of using quick ties and then covering with gorilla tape or window flashing like this:
    Flashing tape
    I was actually thinking of trying to run another brace length wise from brace to brace just as another failsafe so if the bolts break the tank cant slide out of the brackets.
  • Glad you were able to take care of it with little expense, and not too much aggravation. Could have been worse. I've heard gorilla tape being used for that works fine.
  • Glad everything went well. Would another brace help it from moving again? Gorilla tape usually holds. I heard of using quick ties and then covering with gorilla tape or window flashing like this:
    Flashing tape
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
